Hondata mobile has to be uninstalled then reinstlled
Periodoc
Post by Periodoc »
I have a stock 2007 S2K with a Flashpro tune. I have kept the Flashpro connected and bought the Hondata Mobile app version 1.2.9. Once the car is re-started, the app will not connect until it is uninstalled from then reinstalled on my I Phone 11. Is there a solution to this? Thanks.
Periodoc
Re: Hondata mobile has to be uninstalled then reinstlled
Post by Periodoc »
My phone still doesn't link with the app, despite turning phone on/off, bluetooth on/off. It will link if Flashpro unplugged from ECU, but I can't see having to do that each time I want to use the app. Is there an in-line off/on switch that stays plugged into ECU, that the Flashpro can plug into, eliminating the need to physically disconnect from the ECU? Thanks.
Let's start with the basics. Android or Apple?
Periodoc
Post by Periodoc »
As stated above, I phone 11.
What version of ios do you have? Are the lights on the FlashPro on when you try to datalog? Have you paired the phone to the FlashPro?
Periodoc
Post by Periodoc »
Software version 14.8.1. Flashpro is connected to ECU...green power light is lit. I haven't tried to data log. Just want to view the Hondata information. Am I missing something?
Periodoc
Post by Periodoc »
The phone doesn't recognize Hondata app when I try to pair them.
Periodoc
Post by Periodoc »
Also, FlashPro doesn't appear on the phone's list of devices to pair with.
Next question: what version of FlashProManager have you uploaded to the ECU with?
Periodoc
Post by Periodoc »
I have not done that. I thought I just had to install the app on my phone, then connect to FlashPro. No clue as to how to upload FlashPro Manager.
Periodoc
Post by Periodoc »
None of that means anything to me. After I bought the FP, a tuner took over and did his stuff. The FP then sat on a shelf for almost 5 years, when I read about the Hondata app. When I checked it out on YouTube, there was no mention of uploading anything to the ECU. When I unplug, then plug FP to ECU, everything (dashboard, race track...everything) works fine. Once the car is turned off and re-started, the phone won't recognize the FP, so I have to turn off the car, disconnect, then reconnect FP to ECU to get the phone to recognize and connect to FP. I'll go back to the tuner. Thanks for your time.
Periodoc
Post by Periodoc »
I'll give this another stab. The tuner already uploaded the programs when he tuned the car. Hondata mobile app will sporadically connect...once OBD11 is disconnected, then re-connected, so I know it works. But how to do this predictably? How will another upload help if the ECU has already been FlashPro tuned?
Hondata wrote: Wed Dec 01, 2021 8:43 am Next question: what version of FlashProManager have you uploaded to the ECU with?
This also affects the firmware in the FlashPro.
Periodoc
Post by Periodoc »
I have a Mac laptop, with not enough memory to load Bootcamp for Windows. So, I'll get a cheap Windows laptop and go from there. Wish me luck.
