civic cvt Speed limit problem
Civic 2016+ 1.5 Turbo
cyh60108
Post by cyh60108 »
I CVT use the + 6psi program. When the speed reaches 204kph, the fuel is cut off. Can the limit be lifted.
Re: civic cvt Speed limit problem
It can be changed in the rev limits section of the calibration window.
cyh60108
Post by cyh60108 »
Spunkster wrote: Thu Dec 02, 2021 10:31 am It can be changed in the rev limits section of the calibration window.
I changed the speed in the calibration window to 7000 rpm and the speed limit to 300kph. However, the oil supply is still 204kph cut off. Is it because I'm a Chinese car?
I'm not sure what you mean by the oil supply
cyh60108
Post by cyh60108 »
Spunkster wrote: Fri Dec 03, 2021 10:38 am I'm not sure what you mean by the oil supply
After the speed limit in Flash Pro has been modified to 250kph, the speed will not increase when it reaches 204kph, and the turbocharger stops working.
Post the calibration as well as a datalog showing the issue.
RedYung
Post by RedYung »
I think he means fuel supply.
cyh60108
Post by cyh60108 »
Spunkster wrote: Fri Dec 03, 2021 1:11 pm Post the calibration as well as a datalog showing the issue.
I asked the dealer who bought hondata and told me that the TCU of CVT limited the speed. Hondata flash Pro could not modify the TCU, but only the ECU
