Lamda overlay blank display
EbrahimSR4
Post by EbrahimSR4 »
Hi All. Need some help hopefully just settings I need to change. my lamda over lay is blank yet I can see the blocks moving around with a pink background. I am attaching my data log for anyone to check and give me feedback please. I have reloaded hondata S300 software I have restarted the laptop and always shut down after use. I have checked lamda overlay settings. I am using obd1 oem harness and wiring using D14 with plx sm afr - 0-5v wire.
Re: Lamda overlay blank display
Your ECT and IAT are not reading correctly.
EbrahimSR4
Thank you. yes. I tested the wires today and picked an an issue on both so will run new wires directly to the ecu.
