ECU for tsx
96civicex
ECU for tsx
Post by 96civicex »
So im putting an engine from a tsx(2003-2008 acura tsx 2.4l dohc) into my civic and was looking for more information on what hondata ecu I can use. I was planning on going with the 2002-2004 rsx type s but im not sure if the rsx will work for the tsx. I also dont know for sure what transmission im going to go with. If anyone wants to give me more advice on ecu picks, transmissions, or anything else I should know with the swap id much appreciate it.
Re: ECU for tsx
That ECU will work and you will also need an 02-04 RSX engine harness.
96civicex
Re: ECU for tsx
Post by 96civicex »
Awesome, so then will the wiring harness have all the correct plugs and shit for the tsx engine?
Re: ECU for tsx
You will probably have to use an K20 crank sensor.
