2019 Honda Civic Sedan Touring CVT - Canada
Civic 2016+ 1.5 Turbo
4Sparty
Post by 4Sparty »
Hi Everyone I’m in Canada and I have a 2019 Civic Sedan Touring with the CVT.
When connected and locked the FlashPro the only option it had for the 2019 CAN CVT models is for a “Civic 1.5T Canada 2019 EX CVT” and that’s how it recognized my car.
I was able to install the “Civic-Turbo-2016-2 Tuned-High” Civic Turbo CVT 2016,+6psi High Octane but now all the Honda Sensing, CEL, and exclamation warning lights won’t go away. Car turns on and runs.
Any insights would be great.
Thank you.
Re: 2019 Honda Civic Sedan Touring CVT - Canada
If you datalog are there any errors reported?
4Sparty
Post by 4Sparty »
Spunkster wrote: Fri Jan 07, 2022 10:04 am If you datalog are there any errors reported?
I’m not sure, I’ll data log and find out
4Sparty
Post by 4Sparty »
I completed a data log and it didn’t say any errors, but while I was driving all the Honda Sensing errors disappeared, now the check engine light is the only thing on
Post a datalog made now that all it shows is the check engine light.
4Sparty
Post by 4Sparty »
Is this what you mean:
Post the actual datalog, not a screenshot.
4Sparty
Post by 4Sparty »
Thank you, here you go
Was the check engine light on when this datalog was made?
4Sparty
Post by 4Sparty »
yes, it was on the entire time, but when clicked on "error codes" it had nothing
Does the check engine light go off if you unplug the FlashPro?
4Sparty
Post by 4Sparty »
I'll need to confirm that, it's been plugged in the entire time. Thank you for the promptly responding.
4Sparty
Post by 4Sparty »
No More check engine light! Crisis averted, thank you for all the help.
I do have a follow up question, is there a page/post that outlines the differences with the calibrations?
I'm not sure what the differences are between:
1. Civic-Turbo-2016-2 Tuned-High Civic Turbo CVT 2016+,+6psi High Octane
2. Civic-Turbo-2016-2- HighOutput Civic Turbo CVT 2017+ High Ouput (91 Octane minimum)
If you plug the FlashPro back in does the check engine light come back on?
When you click the New calibration button it has a description of all the calibrations listed.
4Sparty
Post by 4Sparty »
Spunkster wrote: Fri Jan 07, 2022 2:29 pm If you plug the FlashPro back in does the check engine light come back on?
I just tested it again, no more CEL.
Thanks again for all the help.
For the Calibrations am I understanding these correctly:
1. Civic-Turbo-2016-2 Tuned-High Civic Turbo CVT 2016+,+6psi High Octane - Up to + 6 PSI depending on Fuel octane
2. Civic-Turbo-2016-2- HighOutput Civic Turbo CVT 2017+ High Ouput (91 Octane minimum) -Better performance than option 1, but can’t use fuel lower than 91 octane
