Engine cutting during boost
Scott Pops
Post by Scott Pops »
I am having an issue with the engine cutting during boost. It does not do it at lower boost settings around 5 psi, but if I turn it up to 8-10 psi, it will do it consistently. From what I can tell, it is not lean protection activating because I don't think I am near the lean threshold (runs 11-12 A/F, lean protection set above 13 A/F for more than a half second). On the attached datalog, the event is from 4:20 to about 4:25. Third gear pull, slowly easing to full throttle, then it just dies/cuts out.
Mr2 spyder with K swap
KManager version 4.5.1.0
ECU P/N 37820-PRB-A06 2068-607737
K24 engine, RBC intake manifold, BorgWarner Efr 7163 turbo, ID 1050cc injectors, Aeromotive 325 fuel pump, DW FPR and return line, air-to-water intercooler, Hondata 4 bar map sensor
Re: Engine cutting during boost
You appear to be hitting a boost cut. Try raising the hot boost cut to 11 psi.
Scott Pops
That fixed it! I really appreciate your help!
