Civic Si 2007 K20Z3 Brazil
Torolho
Post by Torolho »
First of all I would like to thank you for your commitment to share and help the hondata users, this was the main factor for choosing this brand.
I will install the software and at first make the data log of how it is
First doubt is the original map, how do I do it or save it?
The first question is the original map, how do I save it? Is there a place where I can choose the maps and then upgrade them and upload them to hondata and then do the data log?
I am slowly making modifications at the moment I have a complete exhaust pipe with manifold and no catalytic converter and only one muffler, the air filter is still original and soon I will be installing the Cold air intake with this I will be able to make updates as they are installed? Are maps ready and then will be adjusted individually later?
The fuel here is too expensive to have high octane 98, so the most used is common with 92 Is it possible to calibrate with ethanol 112 and gasoline 92 mixture? (proportion 70 gasoline and 30 ethanol) since I do not intend in the medium term to convert nozzles, fuel pump for exclusive use in ethanol.
I apologize for the language because I am still studying to better communicate the technical terms are the most difficult to explain.
Administrator if the topic is in the wrong place I apologize and also want to learn more how to be useful in the forum, my idea is to help people here in Brazil because the mentality is to take the money hiding knowledge and when I found the forum and bought the flaspro I was very happy for the attention provided.
I am not a tuner or workshop owner, just a lover of cars and motorcycles.
Thank you very much
Re: Civic Si 2007 K20Z3 Brazil
Have you read through the help file to get a better understanding of how it all works?
http://www.hondata.com/help/flashpro/index.html
The FlashPro is fully tunable and can be retuned at any time you wish. You will be able to tune for whatever modifications you make and whatever fuel you run.
Torolho
Post by Torolho »
thanks I'm studying, at the moment I'm trying to find out how to make the VIN appear in the ECU
It should show up automatically. If it does not, then it was not programmed properly by the Honda dealer.
Torolho
Post by Torolho »
That's right, I'll contact someone authorized to solve this and then go to the next level
Torolho
Post by Torolho »
Hello, after going to the dealership the VIN was registered in the ECU, I have already performed the map Stock and everything went right to go up and make my first datalog. Follow the file if anyone can analyze. Is there any secret in the acceleration or gear to have a perfect datalog?
I am with complete exhaust a muffler and manifold and today I install the Cold Air Intake and then I will upload other maps
https://1drv.ms/u/s!Agv4RulGu6eb-QK-n29 ... R?e=mnolC0
