Lamda overlay help
MX621
Lamda overlay help
Post by MX621 »
Got my aem series x wideband wired in on AI1 and it’s working fine in the datalog, showing on my display and shows correctly on the sensor list. I switched the sensor overlay to AI1 in settings, but on the lamda overlay it’s just reading 17.5. Looked over everything I’m aware of and from what I can tell it should be working. Anything I’m missing? Thanks
Re: Lamda overlay help
Post your calibration and a datalog showing the issue.
MX621
Post by MX621 »
so i have the wideband 0-5v on the white wire, anolog input 1. i figured out that is does show the correct value if i press: view tab, sensor overlay, it populates the correct wide band info in the cells. press the recorded lambda button, still stuck on 17.6. and shows the estimated change to reach target afr based on the 17.6, not the sensor overlay.
hope im sending what you need fairly new to the platform
MX621
Post by MX621 »
screen shots
If you want to be able to make full use of the wideband input, it must be input to one of the ECU inputs listed in the software. Do not use D14 as it cannot see the full voltage range.
MX621
Post by MX621 »
Thank you for that clarification.
