Need Help with CAM ANGLE. difference between CAMCMD and CAMANGLE
pmateo93
Post by pmateo93 »
Hello,
I recently built my turbo car.
I have stock k20z3. I'm in the process of tuning via datalog with Derek Robinson from Innovative Motorworks.
The car is presenting a difference in the cam angle, a kind of oscillation.
We changed the VTC actuator, Vtc selenoid, VTC filter, VTEC filter, camshaft sensor.
See the attached image. The issue It is more noticeable when the car is cruising, at low speed better cam angle.
Re: Need Help with CAM ANGLE. difference between CAMCMD and CAMANGLE
What vehicle is that? Are you using an 02-04 ECU or 05-06 ECU?
Edit: Sorry, ignore this - got confused with the KPro.
pmateo93
Post by pmateo93 »
Hondata wrote: Thu Feb 03, 2022 8:53 am What vehicle is that? Are you using an 02-04 ECU or 05-06 ECU?
Honda Civic SI 2008 Canadian OEM ECU
What oil are you using?
pmateo93
Post by pmateo93 »
Spunkster wrote: Thu Feb 03, 2022 10:21 am What oil are you using?
Repsol 10w-40
Do you have a restrictor on the oil line for the turbo?
pmateo93
Post by pmateo93 »
Spunkster wrote: Thu Feb 03, 2022 12:35 pm Do you have a restrictor on the oil line for the turbo?
Yes, the turbo has a restrictor.
What oil pressure are you getting?
pmateo93
Post by pmateo93 »
Spunkster wrote: Thu Feb 03, 2022 1:52 pm What oil pressure are you getting?
At Idle: 20-21 PSI
Cruising: 60-80 PSI
WOT: 90 PSI
pmateo93
Post by pmateo93 »
I have this ecu part 37820-rrb-k01 any problem with that ecu?
That ECU is compatible.
pmateo93
Post by pmateo93 »
Spunkster wrote: Fri Feb 04, 2022 10:20 am That ECU is compatible.
UPDATE: We change the ecu and we still have the same issue with the cam angle.
Then it sounds like a wiring or mechanical issue in this vehicle.
vsperformance
Post by vsperformance »
You solved it or still with this issue?
