Problem Selecting Custom map sensor
cpur
Post by cpur »
Hi Guys
New to Honda and Hondata,
Today we started up a recently overhauled k20a2, with an unknown throttle body. Engine on a stand not in car.
I am saying unknown as the tps was reversed and i found that the crv has the sensor on the opposite side of the shaft. So I am thinking that it is CRV .
However the map sensor port is pluged and was not used on the OEM car the tb came from.
I tried to connect it to the brake booster vacuum pipe on the manifold for the time being. However i could not get a live reading of the map if i select a different map sensor from oem. And the problem was not the map sensor . I managed to start the engine with a pot instead of a map but only with oem map sensor setting, if I select custom, (anyone of them ) the value goes to -29.4psi i believe this is the default ,and even with a full sweep of the pot it always remained the same. Could this be a bug?
Software was downloaded last December and the Kpro is the red one.
Thanks and good evening
Re: Problem Selecting Custom map sensor
The software is out of date and must be updated.
If the engine is not in a vehicle and actually running it will not read correctly.
Post a picture of the K-Pro board.
