Enabling Oil Pressure Sensor in Display Sensors
Adamt
Post by Adamt »
I have added an oil pressure sensor, and it has been wired in. But, how do I add it into the KPRO sensors so I can see the output? Thanks in advance.
Re: Enabling Oil Pressure Sensor in Display Sensors
You should see it in the analogs in the sensor list. You can add it to the display by right clicking and adding a value and then select the one you want to use.
