S300 v3 CAN output
aklackner
S300 v3 CAN output
Post by aklackner »
In CAN output documentation there are values for knock/detonation in the Hondata CAN protocol, though it’s noted this is only available on kpro.
I’m using an s300 v3 in a p72-a01 with knock board so in this case values should be in the ecu. Will the s300 send these in this case or does the s300 simply not output?
Re: S300 v3 CAN output
aklackner
Post by aklackner »
Thanks for confirming
