FlashProManager 3.8.8
V3.8.8 (21 Feb 2022)
  • Firmware updated to version 208
  • [FK2] Added idle fuel pressure, flex fuel support, traction control, full throttle shift and anti-lag.
  • [FK8] Added fuel pump PID and feed forward tables
  • [FK8] Added support for 2020 Asia model 5BF-U23
  • [2019+ RDX] Added support for US 2022 model 5YF-AD2
  • [2017+ Civic Si] Added support for Brazil 2019 model 5AM-M11
Download here
Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread under the appropriate vehicle category.
Bain
Re: FlashProManager 3.8.8
Post by Bain »
Hi Admin
WIth the Flex Fuel for the FK2- what kits are compatable?
Same as the FK8 or the 1.5T?
Fuel-IT kits?
thanks
Any device that outputs an analog voltage rather than a frequency signal.
Bain
Post by Bain »
Hondata wrote: Tue Feb 22, 2022 8:47 am Any device that outputs an analog voltage rather than a frequency signal.
Thank you.
MauiSI
Post by MauiSI »
Upgraded to the latest release and when I plug my flashpro in, I get prompted to update the firmware. It is stuck and does not update. I even let it run overnight. Any suggestions?
Unplug the FlashPro from the vehicle and USB, then only plug in the USB and try again.
Hondata wrote: Mon Feb 21, 2022 5:14 pm Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread under the appropriate vehicle category.
jeffx
Post by jeffx »
Hondata wrote: Mon Feb 21, 2022 5:14 pm V3.8.8 (21 Feb 2022)
Will there be some further details on the significance of the feed forward tables and other changes for FK8?
I do not think so. There were put in for people using other fuel pumps, and if you have worked with PID control and feed forward tables then they are fairly self explanatory. It's one thing describing the tables but I really don't want to get into training people on the PID/FF.
The broader issue is that we added support for the XDI pump without the user being able to change anything other then enabling the pump. This way we take ourselves out of the loop if there is a tuning problem with the pump (so far there have not been any problems that I know about). The tables will get copied into other tuning software but at some point looking after people using our software is more important.
KT7788
Post by KT7788 »
Hi guys
After i upload with the lastest software 3.8.8
My Fk2 cannot start up .
It show A, engine , CTBA , ding ding ding .....
So i retry again, now it cannot detect ECU.
Did it bricks the Ecu ?? Or the software have any bug ?
KT7788
Post by KT7788 »
Hi Guy
Software 3.8.8
Model : FK2
Add on , Anti-lag & Flat throttle Shift
After Flash in the files .
The ECU went into protection mode, cant start the car .
Prompt A, Engine , CTBA Logo ding ding ding .....
Try to flash , ECU in protection , Flashpro cannot even detect ECU.....
Everything unplug , switch off , locked the car , when for a break around 30 min
Came back , Thanks god .. the ECU is out of protection mode.
Able to flash in without the 2 feature anti-lag and FTS
The Fk2 is working again.
Is there some bug on the 2 features ?
Can you guys please look into it .
Thanks, we will look into this. If you could post the calibration that caused the problem here it would help. Also sending feedback with the FlashPro plugged into the vehicle would help a lot too.
jeffx
Post by jeffx »
Hondata wrote: Fri Feb 25, 2022 5:10 pm I do not think so. There were put in for people using other fuel pumps, and if you have worked with PID control and feed forward tables then they are fairly self explanatory. It's one thing describing the tables but I really don't want to get into training people on the PID/FF.
Thank you, that is exactly what I was wanting to know.
KT7788
Post by KT7788 »
Hondata wrote: Mon Feb 28, 2022 8:24 am Thanks, we will look into this. If you could post the calibration that caused the problem here it would help. Also sending feedback with the FlashPro plugged into the vehicle would help a lot too.
Hi guys
Only 2 extra features were turn with the base map.
- antilag & FTS
After flash, ECU go into protection mode.
Cant start .
After 30min i able to flash back to without the 2 add ons.
https://youtu.be/6BJOvZbq4NI
Bain
Post by Bain »
This is some good info, thank you.
So you will be looking at the XDI pump to be added for the FK2 also?
