Needing a lsv turbo base map just to break in the motor before I take it to the tuner to dyno(given he’s almost 4 hours away)
Here’s my set up
Gsr head freshly machined stock cams and valve train
Bbk ssi 5007 intake manifold with skunk 2 74mm tb
FIC 2150cc injectors
Aem regulator (-8 feed, -6 return) on e85
Walboro 525 pump
B18a1 block
9.8:1 cp pistons and Manley rods
Fresh stock crank
1320 top mount with borgwarner sx200 turbo
3” intercooler with piping
44mm tial wastegate and vsr bov
4 bar map sensor
Stock ls trans non lsd
Acp clutch unknown flywheel
P72(vtec converted) with hondata s300
Thanks guys
Any help with a base map for ls vtec turbo?
Tlcpsilver06
- CalibratEd
- Contact:
Re: Any help with a base map for ls vtec turbo?
I can help out. Are you able to provide datalogs with wideband data?
-Ed
-Ed
Instagram: calibrated.tuning
Tlcpsilver06
Data logs yes but I haven’t hooked up the wideband since I haven’t finished my charge pipe
- CalibratEd
- Contact:
Reach out when you have the wideband installed.
-Ed
-Ed
