K24/K20 12.5, DC4 Cams Basemap?
dee_eh2
Post by dee_eh2 »
I recently just got the car wrapped up and am trying to bleed the car and get it good enough to drive onto a trailer to get the exhaust welded/alignment done before heading in for a tune.
I have a previous tuned map for a stock k24 fbo that I tried to get the car idled on but I have a surging idle. I've checked the intake manifold gasket, tb gasket, injectors. I am running a karcepts iacv block off plate with iacv turned off. The car from a cold start will idle normal until warm and then start to surge.
Engine setup is 12.5 compression with a stock k20a2 header, drag cartel 4 cams, intake, header, exhaust. I am hoping someone has a basemap close to my engine setup that is willing to share just so I can get the car idling. Feel free to make other suggestions as well.
CalibratEd
Re: K24/K20 12.5, DC4 Cams Basemap?
Post by CalibratEd »
Have you double checked for vacuum leaks after the engine has reached operating temperature. Can you post the current calibration file and a datalog with the issue.
-Ed
Instagram: calibrated.tuning
