Launch control switch options
diegiton1
Post by diegiton1 »
Hi.
I have a ek with k20z3 turbo swap.
My speed signal have problems and is impossible that work again.
I can't use the lauch control because the signal vss always is cero.
Now I need use a switch for activate and deactivated the lauch control.
Has anyone done it, could you give me a hand? I would be very careful 🙏
Re: Launch control switch options
The ECU will need a proper speed sensor input.
What is the ECU part number you are using?
What is the serial umber on the K-Pro board inside the ECU.
diegiton1
Post by diegiton1 »
I am using a PNF ecu and kpro v4. Remember that I have one problem with the vss and is impossible that work. Because that I need alternative lauch control switch for activate
You need to determine why the speed sensor does not work and fix that.
