Check Engine Light
ChrisPR
Check Engine Light
Post by ChrisPR »
New to the form.
I just received flash pro(race) for my 2021 civic hatch sports touring(cvt). I registered, lock to car and loaded the 6+ psi high octane tune. Car is completely stock, only 9k miles. I know all dash lights come on and go away while driving which all did expect for check engine light. The software on pc ain’t reading no codes even though engine light on. I went and got hondata app and samething, says no check engine light is on even though it is. I freaked out so I returned ecu to stock and the check engine light is still on. Don’t know what to do at this point, if anyone can help I would appreciate it.
Re: Check Engine Light
Using FlashProManager hook up to the FlashPro and FlashPro to vehicle, switch on ignition and then go to 'OBDII Diagnostics'. From there go to the 'Diagnostics' tab and refresh the DTC list. You can clear all the DTCs from there too, but first record what DTCs there are.
ChrisPR
Post by ChrisPR »
There was no DTC's thats why i was lost about why check engine light was on. But jumping to this morning, i turned on car and no check engine was present. I am running the plus 6 high octane tune, i connected laptop to flashpro and drove and i notice im only hitting 16-17 psi, shoudnt i be hitting more?
Did you use the OBDII Diagnostics window to check for DTCs, or some other method?
ChrisPR
Post by ChrisPR »
I used the OBDII window on Hondata software. Online>OBDII Diagnostics>DTCs and no codes were present, even after refresh. I even downloaded hondata app on phone and same results. But when i turned on car this morning the check engine light was gone, not sure what happen.
janemar
Post by janemar »
Hondata can only read ecm related CELs. So most problably you have issue which is non ecm/engine related like in transmission or abs, for example.
OBDII Diagnostics window will show DTCs from modules other than the ECU as well.
I suspect the MIL was from reflashing and it went away after a short drive.
Slwfk7
Post by Slwfk7 »
I’ve been have the same problems since the new updates. It’s in the bcm. I hen I got my hondata a year ago I didn’t have this problem after uploading a tune. 2018 Honda Civic hatchback. E85 and fbo.
dudzkhalifa
Post by dudzkhalifa »
Hondata wrote: Mon Mar 07, 2022 9:08 am OBDII Diagnostics window will show DTCs from modules other than the ECU as well.
I also experiencing check engine light after a tune. Didn’t find any error on OBDII diagnostics window and also in apple hondata app, didnt find any error but check engine light is on.
Can somebody help me
