New Here!!!! I Need a base map
JaviBori1
Post by JaviBori1 »
Im new in here!!!!!
If not allow delete
Kpro v4
Need help finding or getting a basemap for K20a2 swap on 96 civic ex
Here are the mod thank
SK2 Alpha Valve Spring & Ti Retainer Kit - K Series
344-05-1410
SK2 Tuner Stage 1 Camshaft - K Series
305-05-0220
SK2 Pro Intake Manifold - K20A2 Style
307-05-0310
SK2 Alpha Valves - STD Comp K Series - 35mm/ 30mm
310-05-1535
Sk2 Spring Base Kit - K20/ K24 & F20C/ F22C 312-05-0010
SouthBay Fuel Injectors - 1000cc
DeatschWerks 9-201-0846 - DeatschWerks Fuel Pumps 255
K-Tuned 4 BAR MAP Sensor for K-Series Honda Engines
Hybrid Racing Silicone Cold Air Intake Velocity for K-Swap EG/DC/EK Honda Civic
Ramhorn K-SERIES SWAP K20 K24HEADER 92-00 CIVIC 94-01 INTEGRA EG EK DC2- Blemish
K-Tuned 72mm Throttle Body for K-Series K20 K24 RBC/RRC/PRB/PRC pattern
ATI Street Super Damper Crank Pulley 918477 for Acura Honda K20A K20A K20Z K24
ARP 208-4701 Cylinder Head Studs Honda/Acura 2.0 DOHC i-VTEC K20A2 K20A3
GENUINE ACURA RSX HATCHBACK (2002-2006) Gasket, Cylinder Head 12251-PRB-A01
Ferrea Valve Guide for Acura Honda K20 K24 RSX / Civic Si - STD VG1064 VG1062
Supertech Valve Stem Seals Acura K20a K20a2 K24 K24a2 RSX TSX
TRC Honda Acura K20A2 OEM PRB Oil Pump Kit Fits K24 / K20Z3 K24A1 K24A2
OEM Honda S2000 AP1 Civic Si B16 Valve Cotter Set Keepers 14781-PR7-A01
Honda Genuine OEM K20 Water Pump 19200-PRB-A01 NEW 2.0L DOHC VTEC K20A2 K20Z1
Honda K-Series Lost Motion Springs (Set of 8) K20 K24 - 14820-PNA-013
K-Tuned A/C & P/S Eliminator Pulley Kit for Honda/Acura K20 K24 Engines
Drag Cartel Billet Lower Timing Chain Guide Honda K20 K20A K20A2 K20Z3 K24 K24A2
CalibratEd
Re: New Here!!!! I Need a base map
Post by CalibratEd »
I can help out. What is your plan? Do you plane to get it E Tuned or do you plan to drive it to a tuner? Can you provide datalogs with Wideband data?
-Ed
Instagram: calibrated.tuning
JaviBori1
Post by JaviBori1 »
CalibratEd wrote: Mon Mar 14, 2022 11:28 am I can help out. What is your plan? Do you plane to get it E Tuned or do you plan to drive it to a tuner? Can you provide datalogs with Wideband data?
-Ed
I’m planning to drive it to the tuner (20min drive)… The car currently will not start. Im new to hondata & Kswap…
Sorry for making it a little bit difficult
Thank you
CalibratEd
JaviBori1 wrote: Mon Mar 14, 2022 4:18 pm
-Ed
Thank you
I would ask your tuner to see if they can provide you a base file to get you to the dyno. I know that some tuners do that. In the meantime do you have the injector data.
-Ed
