Waste gate disable
xiplus
Waste gate disable
Post by xiplus »
My car is a 2020Civic FK7 Hatchback. I join + 6 psi
ECU program. There isa Disables factory waste gate controller in the MODS option. Only use this if you have an aftermarket turbo which does not use The factory wastegate controller"
Can only the non-original turbocharger be used
Re: Waste gate disable
Why are you trying to disable this?
xiplus
Post by xiplus »
It is invalid when written
