Green key light in civic SI 2006-2011 ecu (after swap)
MarcinPL
Post by MarcinPL »
Hi, I have problem with green key light on my dash and cannot turn on my engine.
Short info: It is in Honda civic 2006-2011 fd1 (originally was R18a2 engine) after swap to K24A3 (with civic Si 2006-2011 engine harness and ecu). So my question is: Is it possible somehow to disable immo on my ecu? how I can do that? maybe by hybrid racing immo bypass: https://www.hybrid-racing.com/products/ ... elete-chip? or maybe is there an easy way in Flashpro (I have it but haven`t switched it to ecu yet). My local honda dealer will not be able to help probably as I`m in PL and ECU is from USA.
Re: Green key light in civic SI 2006-2011 ecu (after swap)
No, you cannot disable the immobilizer in the FlashPro. You will have to get the immobilizer working as it is supposed to and matched to the ECU and keys.
MarcinPL
Post by MarcinPL »
Thanks for reply, and do you know maybe if it will work with this Civic Si ECU and engine harness? I think that an sensor is blocking start
I'm sorry, but this is not something we can assist with.
