Flex Fuel - Base Map
Rose
Post by Rose »
Hi there,
I am currently driving a 2018 Civic EX-T, Manual Trans, with a few mods.
I just recently got my Flashpro installed, and also the PnP E85 Flex Fuel kit.
While combing through the basemaps, I do not see anything for a 2018 Civic EX-T MT Flexfuel.
Anyone have any recommended basemaps I can try out? Or will I have to finetune myself in the calibration software.
Any and all input is welcome
Thank you
PS: The only basemap calibration I believe fits my vehicle specs would be as followed:
Civic Turbo MT 2017+ , 265kpa max, 100 octane minimum
Civic Turbo MT 2017+ , 265kpa max, 93 octane min
Civic Turbo MT 2018 Base Calibration
Should I simply use the base calibration, tweak the calibrations that I would prefer (such as improved turbo response) and then enable ethanol input?
Would the Flashpro do the rest for me safely?
2018 , Honda Civic , 1.5L , EX-T , Injen CAI , Injen SES 3" Cat-Back Exhaust , SiriMoto PnP E85 Flex Fuel Kit , Stage 3 Clutch Kit w/ Ultra Light Flywheel , Sirimoto N1 Clutch Master , MAPerformance Catted exhaust
Re: Flex Fuel - Base Map
There is a 9psi flex fuel calibration you can use, but you will probably need to upgrade your clutch for this.
Rose
Post by Rose »
Hey Spunkster,
Is the basemap you are referring to:
Civic Turbo MT 2016, +9psi Flex Fuel. Clutch upgrade highly recommended
If so, is this safe to run on the 2018 Civic?
(Follow up question: Are you able to use basemaps from a different year so long as they are still 10th gen and match the parameters of my 2018?)
Thank you for your help :)
That is it and should be able to be used.
monchiy2k
Post by monchiy2k »
im looking for that fuel map, where i can gei it?
CalibratEd
Post by CalibratEd »
monchiy2k wrote: Mon Jul 15, 2024 9:10 pm im looking for that fuel map, where i can gei it?
The file is provided by Hondata. When selecting a file change model to Civic 1.5T (2016-2012) and change vehicle to Civic 1.5T US 2018 MT. Once you do scroll though the tune files and select the one mentioned in the thread.
- Ed
Instagram: calibrated.tuning
monchiy2k
Post by monchiy2k »
thanks
CalibratEd
monchiy2k wrote: Tue Jul 16, 2024 10:42 pmthanks
No problem.
-Ed
