Need a base map for a jrsc k20/k24
mrhype1
Post by mrhype1 »
Any help is appreciated Thanks In Advance,...I just got my motor built. It's a 2006 rsx-s k20z1 head on a k24a Tsx block along with a Jackson Racing Supercharger on 11psi of boost.
CalibratEd
Re: Need a base map for a jrsc k20/k24
Post by CalibratEd »
I can help out. Can you provide datalogs with wideband data? What is your plan for the car? Do you plan to get it dyno tuned or e tuned?
-Ed
Instagram: calibrated.tuning
DRamos28
Post by DRamos28 »
im also doing a K24/K20 and need help with a base map tune can anyone help me out i have K24a4 block with a K20a2 head rbc cams prb intake manifold 70mm throttle body hybrid racing fuel rail and 1000cc injectors can't get car to start only cranks i disabled the immobilizer on my rsx but still nothing no check engine light comes on door nor the green key light plzz help
CalibratEd
DRamos28 wrote: Tue May 03, 2022 8:40 pm im also doing a K24/K20 and need help with a base map tune can anyone help me out i have K24a4 block with a K20a2 head rbc cams prb intake manifold 70mm throttle body hybrid racing fuel rail and 1000cc injectors can't get car to start only cranks i disabled the immobilizer on my rsx but still nothing no check engine light comes on door nor the green key light plzz help
Sure start your own thread. If you have double checked your electrical system, check the basics. Make sure you have spark, compression and fuel.
-Ed
mrhype1
Post by mrhype1 »
CalibratEd wrote: Mon Apr 04, 2022 3:23 pm I can help out. Can you provide datalogs with wideband data? What is your plan for the car? Do you plan to get it dyno tuned or e tuned?
-Ed
Sorry for the late delay. finally gotten a chance to do the datalogs. Any help is appreciated.
mrhype1
Post by mrhype1 »
here is the kal im using for my setup so far. I know it needs a few adjustments, because my mechanic told me my car was running very lean. Thanks for the help.
CalibratEd
Yes, the car is running lean. I recommend to use a wideband when you are force inducted. I also don't recommend using random files you find online.
What map sensor and injectors are you running? Do you need a full tune or something that is drivable?
-Ed
mrhype1
Post by mrhype1 »
im using Hondata Kpro v2 Bluetooth. my map sensor is a hondata 4 bar. my injectors are injector dynamics 725cc. i need a tune good enough to get me to a dyno to get a full tune. unless you can help me with a full tune. Thank You
mrhype1
Post by mrhype1 »
CalibratEd wrote: Wed Feb 08, 2023 8:25 pm Yes, the car is running lean. I recommend to use a wideband when you are force inducted. I also don't recommend using random files you find online.
-Ed
CalibratEd
mrhype1 wrote: Thu Feb 16, 2023 8:17 pm
-Ed
Do you have a wideband installed? I can help you with a tune to get you to a tuner or provide you an Etuning service. It is up to you.
-Ed
mrhype1
Post by mrhype1 »
CalibratEd wrote: Tue Feb 21, 2023 6:47 am
-Ed
-Ed
I'm a running a oem Denso o2 sensor from a 02-04 rsx type-s as a wideband. I would like to get a full e-tune from you. What you charging and what payment do you prefer. Thanks
CalibratEd
I pm’d you the details I use PayPal. Do you plan to get an aftermarket wideband?
-Ed
CalibratEd
Here is the base file. See if the car starts and idles. If so create a datalog of the car at idle and let it reach operating temperature. If possible create a normal driving log.
-Ed
mrhype1
Post by mrhype1 »
CalibratEd wrote: Thu Feb 23, 2023 9:43 pm Here is the base file. See if the car starts and idles. If so create a datalog of the car at idle and let it reach operating temperature. If possible create a normal driving log.
-Ed
here are the datalogs you asked for. didn't get a chance to do the driving log. weather isn't permitting at the moment
mrhype1
Post by mrhype1 »
Hey Ed! Thanks bro for the help! I finally gotten a chance to get my car tuned on a dyno here locally. 👍👍
