Bosch PST F-1 Press/Temp Sensor
compression
Post by compression »
I am using a Bosch PST F-1 pressure/temp dual sensor for oil on my K-series honda engine.
https://www.bmotorsports.com/shop/produ ... ts_id/4692
My question is, how do I wire this sensor to the analog inputs on the K-Pro?
There are four wires coming from the sensor (shown in diagram below) and it is documented that you want to use a 1K pull-up resistor on the temp signal....which I do not know how to wire. Any guidance would be greatly appreciated.
Re: Bosch PST F-1 Press/Temp Sensor
I don't know if you will be able to use this single sensor with the K-Pro
Sensor 5V goes to an ECU VCC pin and sensor gnd goes to one of the ECU SG pins.
Use a 1.5k pull up for the temperature.
http://www.hondata.com/help/kmanager/an ... rature.htm
Pressure gets wired in without a pull up.
http://www.hondata.com/help/kmanager/an ... essure.htm
pistol pete
Post by pistol pete »
Hondata wrote: Wed Apr 06, 2022 2:59 am Sensor 5V goes to an ECU VCC pin and sensor gnd goes to one of the ECU SG pins.
I have this bosch sensor wired in.. For the pressure set up on the K manager. What do I select the conversion as?
Pete
