Launch Control always working when load map into chip
AKAPitu
Post by AKAPitu »
Hello all, greetings from Spain.
I'm trying to load an s300 calibration fully working into a chip for p28, but launch control is always on, even when i disable launch control in smanager. I tried every combination with all options, inverting output, with and without burnout rev limiter.... im going crazy.
If i set launch control under 4700, it works at the rpm set with the chip, but if i set rpm above 4700, launch control stays at 4700.
I tried to change launch control speed limit to 0 but it changes to 1...
Always using the same calibration with the s300 board which works fine and launch control do what is supposed to do.
I use <pirate software link removed> to convert .skl (smanager calibration) to .bin and moates chip burner with flash&burn by moates to write chip.
Hope you can help me, thank you very much.
Re: Launch Control always working when load map into chip
We do not support piracy. Purchase an s300 if you want to use our software.
You're stealing from the people who work at Hondata. Buy an s300 if you want it to work.
