2022 Si Rev-Match not functioning properly
Civic 2016+ 1.5 Turbo
BmerrillFE1
Post by BmerrillFE1 »
I recently got the Flashpro for my '22 Si and uploaded the 250 lbs-ft calibration to my car, however, the Rev-Match system doesn't appear to be functioning properly. Has anyone had this problem and have any way to resolve it? Also, I have disabled rev hang, could that be the culprit?
Re: 2022 Si Rev-Match not functioning properly
In FlashProManager open the diagnostics window, open the diagnostics tab and clear dtcs
https://www.hondata.com/help/flashpro/o ... window.htm
BmerrillFE1
Cleared all dtc's and it functions good in normal but not in sport mode, tried multiple flashes with various settings enabled/disabled
Post your calibration as well as a datalog showing the issue in both modes.
BmerrillFE1
Here is the calibration I have uploaded currently as well as datalogs for both modes. The problem is it doesn't Rev-Match upon downshift. There are no codes or dtc's.
What happens if you disable the Sport button boost in the Torque section?
BmerrillFE1
The problem is still present when Sport button boost is unselected. If I press the cruise control button it works but I lose all the power from the tune in either mode.
