Can’t upload to s300
Gamish
Post by Gamish »
I’ve searched on all the forums about the s300s upload button being greyed out. It says it’s some sort of socketing issue, I presume that means that I soldered the pins in wrong. My d2 light is flashing red and my d1 light is solid green. Any tips?
Re: Can’t upload to s300
Is it plugged into the vehicle wit the ignition in the on position?
Gamish
Post by Gamish »
I am on version 2.7.8.0
Gamish
Post by Gamish »
And it is plugged into the vehicle with the key in the on position
Gamish
Post by Gamish »
I got it socketed but burton racing because I figured I had just socketed it wrong and wanted to make sure it was correct and they tested the ecu and everything worked, but I’m still having the same issue.
Post a picture of the soldering on the bottom of the ECU.
Gamish
Post by Gamish »
The solder looks good to me but I also suck at it lol
When they tested it were they testing with your s300?
Gamish
Post by Gamish »
No they didn’t even have mine, do you think it’s an issue with the s300?
More than likely it is not the s300. IT does look like the capacitors were not replaced in the ECU when it was socketed. That could be an issue as well. I would have the shop the socketed and tested it test with your s300 and have them replace the capacitors in the ECU.
Gamish
Post by Gamish »
They said that they replaced the capacitors, the first image I uploaded of the top of the ecu was the one I did where I didn’t replace the capacitors but I think the new one they did. But here is a pic of the top of the new one
What is going on in the circled area? This does not look normal
Gamish
Post by Gamish »
I thought the same thing when I got it but figured they knew more than I did
Gamish
Post by Gamish »
This is my first time doing really any modifications to cars
I pretty much got the engine with most the parts I need and built it and put it in so anything with maybe grounds or something could be it but I’m not sure what would cause this other than socketing
That is not original and am not sure why anyone would modify this.
