2014 civic si car sputter help please
thpham
Post by thpham »
dynotune and everything in perfect shape and power 346whp with 10.4psi on 91oct no knock. after dyno done i took a test drive on street, car ran fine after 5min then injectors duty turn off and sputter. then i turn key off and run again and it is fine in 5min then boom happen sputter. cal and log attached please help. any concern recommendation such as fuel pump or ecu or relay or coil or etc....thank you for your time
Re: 2014 civic si car sputter help please
You have 5 error codes for misfires. Have you discussed this issue with your tuner?
Are you using an aftermarket clutch and flywheel?
thpham
Post by thpham »
spunker yea i have talked to the tuner. we did erase the code and it is drive fine. after 3to4 min cruising it show up fuel status error then sputter (misfire). injectors show 0ms at 3k rpm. i have no check e light when it sputter but would u show me how to look up check engine code in flashpro. and yes i have competition stage 4 clutch kit. it happen while switch to open and back to close loop within 3krpm. thank u
Have you tried disabling the misfire detection? This is usually triggered by an aftermarket clutch and flywheel.
thpham
Post by thpham »
spunker. in the misc the tuner uncheck everything except misfire detection. i will talk to him about it. also tuner wants to replace upstream o2. we will do that and test drive again then i will let u know. thank u so much
