B20 Vtec Problem With sensor map
gibonek20
Post by gibonek20 »
Hello I have a honde civic mb6 vti with a b20 vtec engine, my engine specification is
b20z1 engine Ycp High compression pistons 84.50
head b18c6 camshaft b18c4
intake manifold skunk2 pro, throttle body professional product 68 mm, injector 310 k20a2, fuel pump walbro 255
exhaust header 2.5 toda,my problem is that this car does not have power and does not want to drive despite the correct afr at wot, I recently looked at my runs and noticed that the map sensor at wot sometimes shows 0.0 psi, as if it would lose the signal, is it normal behavior of the sensor maps that when wot shows 0.0 psi for a while?
<a href=https://naforum.zapodaj.net/5ff7624ab546.png.html><img src=https://naforum.zapodaj.net/thumbs/5ff7624ab546.png alt=hosting zdjęć zapodaj.net /></a>
CalibratEd
Re: B20 Vtec Problem With sensor map
Post by CalibratEd »
Post the calibration file and datalog directly on the forum. The map sensor could be failing or you have an electrical issue.
-Ed
Instagram: calibrated.tuning
