Catching up! Undocumented features?
Haltamer
Post by Haltamer »
I've just installed the latest version after having left things alone for a while and I've noticed a few new things that haven't been in patch notes that I've seen.
Firstly, Idle speed control for the FK8 - Super, I was hoping to adjust this to compensate for the engine mount - I understand the ECT, but what does the 255/0/1/2/3/4/5/6/7 scale relate to?
Second, I notice there is now a Stock Fuel Pump (Alternate) in the mod list - any info on this / checking if I have said fuel pump?
Re: Catching up! Undocumented features?
The vertical scale 255,0..7 is gear. 255 is reverse, 0 is neutral, 1 is 1st etc.
With the FK8 Honda uses two different settings for the stock high pressure pump. We've had to designate them as 'stock' and 'stock (alternative)'. There's no difference in the way they will work, but due to the way the modifications work we had to separate them out.
