Hi, please excuse my ignorance
GONZO_MARX
Post by GONZO_MARX »
I'm wondering if my vehicle has any default base maps to use? I have a 2018 Civic Sport Touring HB. I checked the ECU # and your site said it was supported. But going through the available tunes, I see a 2017 & 2019 calibrations for The "Honda civic sport touring" but not one specifically for 2018. I see one for "2018 CVT Touring". Which would I use?
GONZO_MARX
Re: Hi, please excuse my ignorance
Suppose I should also mention that I have the CARB edition Flashpro -with that being said it it looks there would only be two maps. the 2016+ 1.5L the +3 and +6 psi maps. Is this correct?
2017 and 2018 are the same and use the same calibrations. The CARB version will have very limited amount of calibrations as it cannot alter emissions.
GONZO_MARX
Understood. I very much appreciate you getting back to me on this.
Just flashed the +3 psi carb map and it seems that the check engine light is persisting. And on dash it says that my automatic high beams aren't working... I tried clearing codes via flashtool but these won't go away. Is this something that will go away given some time? Please advise and thanks in advance!
You need to datalog and see what the actual error is that is reported.
