Failed ecu flash. Error code step 5
Mikemehow
Post by Mikemehow »
Tried to reflash my ecu and it failed. Plugged the flashpro back into a laptop and code error code step 5.
-Locked the flashpro to my vin.
-Calibrated a flash onto the flashpro
-Plugged into obd port but the program like only stays solid red and then turns off.
- car will not start now and cant reflash back to stock
-Flashmangaer is updated to the newest update
The car did have a engine swap from another k20z3 and is it possible that the vin the ecu is thinking of is not the same as the vin on the windshield? I am using a desktop pc so I was not able to have the flashpro hooked up to the flashmanger and the car all at once.
Mikemehow
Re: Failed ecu flash. Error code step 5
Post by Mikemehow »
Flashpro manager version 3.9.3.0
Flashpro serial number fp-si-us-236554
Vechicle vin 2hgfg21519h100700
Vehicle 2006 civic si
Ecu number 3869-106598
Mikemehow
Post by Mikemehow »
Spunkster wrote: Thu May 19, 2022 9:38 am With everything plugged in and the ignition in the on position, go to the Help menu and click on “send feedback”. Include a detailed description of the issue.
Thanks for your help. Got it figured out and working !!
