FK8 2017 throttle plate off and on
bestlap
Post by bestlap »
FK8 full throttle pedal 100% but the Tplate off to 53%, R mode with TC fully off, what can cause this throttle plate off and on?
thank you
Re: FK8 2017 throttle plate off and on
Boot command drops a lot with VTEC so the ECU uses the throttle to control boost.
bestlap
Post by bestlap »
Hondata wrote: Sun May 22, 2022 6:51 am Boot command drops a lot with VTEC so the ECU uses the throttle to control boost.
Request more throttle toq to make the boost CM higher?
Thanks a lot you help!
Kl
bestlap
Post by bestlap »
try everything to CMBP higher but still doing the same WOT the Tplate still off half to try lower my boost. always around 4500rpm start off Tplate.
boost PA disable
R+ mode
VSA and TC fully off
is it the Honda TC still working internal somehow?
Your air charge seems to be exceeding the limits set in the calibration.
