Kpro V4 on “PPL” ecu
MT-Garage
Post by MT-Garage »
Hello,
I recently got a hondata Kpro V4 with a PPL ecu from an authorized dealer.
I am having issues on tuning my k24 with the cam degree? Everytime we just rev the car it shoots all the way to 26 and there is a P0010 VTC code.
I tried another Kpro V4 “PRB” with the same base map and everythingworks out perfectly with no issues
Thanks!
Re: Kpro V4 on “PPL” ecu
What wiring is in use? 02-04 or 05-06? Has either ECU been prepared for 05-06?
MT-Garage
Post by MT-Garage »
02-04 DC5 harness on an EG chassy
MT-Garage
Post by MT-Garage »
It looks like this was sold as an install kit to Tri-State Performance LLC. I would recommend that you have them test this for you to see if it is working correctly. If the ECU is damaged you should be able to supply them a working ECU to have the K-Pro installed into.
MT-Garage
Post by MT-Garage »
Okay thanks, will just bring it back.
I bought the whole ECU kpro’d already from them.
