Flashpro stopped responding while programming, car doesn't start
Ninty
Post by Ninty »
The first time I tried to program the tune, the program light came on, but then the power light turned off and turned back on after a few seconds, then the program and power light turned off.
After all that the program failed and the car will no longer start (unprogrammed ecu?)
When plugging the Flashpro back into my computer, it showed that there was an error due to the ECU no longer responding while flashing, and it said to check the obdii pins. The pins look fine, so now I'm just worried the flashpro isn't working properly?
I submitted this as feedback to Flashpro but if anyone could tell me what else I can do please let me know, thanks.
Re: Flashpro stopped responding while programming, car doesn't start
Unplug the FlashPro form the vehicle and unplug the USB from the laptop and then plug everything back in and try again.
What is the serial number? We get a lot of unsolicited feedback sent and need the serial number to match it with a customer.
Ninty
Post by Ninty »
Hi Thank you for the replies.
I believe my car battery was just low because after retrying with a laptop connected it worked.
