My Knock control keeps rising on every pull
destinray26
Post by destinray26 »
I’m running the +9 psi and every time I do a pull my knock control goes up to 65-70 which I feel is not good. Anyone have any ideas or things I should check???
Re: My Knock control keeps rising on every pull
What brand and octane fuel are you using?
destinray26
Spunkster wrote: Tue Jun 14, 2022 3:05 pm What brand and octane fuel are you using?
I use 91 from shell or chevron
destinray26
destinray26 wrote: Tue Jun 14, 2022 2:57 pm I’m running the +9 psi and every time I do a pull my knock control goes up to 65-70 which I feel is not good. Anyone have any ideas or things I should check???
I also have the skunk 2 ... dp and fp with the injen SRI
Has it been tuned on the dyno?
destinray26
Spunkster wrote: Tue Jun 14, 2022 3:33 pm Has it been tuned on the dyno?
No just the tune on the flashpro is all that’s been done, stock calibration works fine so I’m thinking something might be off with the tune
Post your calibration as well as a datalog showing the issue.
destinray26
Spunkster wrote: Tue Jun 14, 2022 4:45 pm Post your calibration as well as a datalog showing the issue.
Okay so this should be the tune I'm using along with a data log from earlier today. on the hondata app my knock control got up into the 70's. please help ive been having this problem for almost a year.
destinray26
Also my AFR seems a little off it says the target is 14.7 but on the app it drops down to 8-9 ish
The engine is not running in the 4 second datalog.
destinray26
Spunkster wrote: Wed Jun 15, 2022 9:29 am The engine is not running in the 4 second datalog.
so sorry I sent the wrong data log this should be the right one
See if you get the same issue if you use a calibration that runs less boost.
destinray26
Spunkster wrote: Wed Jun 15, 2022 11:16 am See if you get the same issue if you use a calibration that runs less boost.
Do you want me to turn off the optimized turbo response or switch to the +6 psi ?
Try the 6psi calibration
destinray26
Spunkster wrote: Wed Jun 15, 2022 11:39 am Try the 6psi calibration
okay so this should be the +6 psi calibration and i got a data log
