Increasing Injector Size
ED6
Post by ED6 »
I need to understand the science behind the Stock vs Current injector size in SManager. I grabbed the "stock B18C-R" map and am trying to modify it to add my RC 310cc injectors. I went into the program and adjusted the volts / dead time settings as per RC's specifications. But what I don't get is how SManager processes the injector size upgrade. Do I just put 310 under Current Injector Size, or should I have that in both fields? This is the first basemap this ECU will receive before I try to turn the car on.
Re: Increasing Injector Size
You should leave the stock size alone and only change the current injector size. The changes are made behind the scenes and you will not see any changes to any tables.
ED6
Post by ED6 »
OK thanks I'll leave it the way I have it.
