2022 civci si refresh ECU only on sports mode
zecophy
Post by zecophy »
Hi,
Is it possible only overwrite the ECU on sports mode, and still stay stock ECU setting on normal mode?
If possible, how? I tried but did not find any explicit thing relate to it. After rewriting ECU with hondata 240lbft canned tunning, I feel normal mode also be changed.
My car is 2022 civic si mannual
Re: 2022 civci si refresh ECU only on sports mode
You can use the Hondata Mode function: https://www.hondata.com/help/flashpro/h ... htsub=mode
This will allow you to edit torque for the 2 modes independently.
zecophy
Post by zecophy »
Thanks for replying!
In 2022+ civic si, seems there is no such option existing. If you see the screenshot, there is no such Hondata mode selection under rev limit parameters...
It is in the torque section.
zecophy
Post by zecophy »
awesome, thanks!
