Idle drops low
Furious
Idle drops low
Post by Furious »
Hello Hondata,
I have an issue with FN2 I never had before with other Flashpro cars.
This is Euro FN2 K20Z4 with supercharger. The case is that when car is going to stop, clutch and brake pedal is pressed, the rpms goes very low, sometimes engine stops. The same happens on idle, rpms goes very low, when additionally brake pedal is pressed engine stops.
MAF sensor is discronnected, IAT plugged into intake manifold.
Map and logs attached.
Thank you,
Tomek
Furious
Re: Idle drops low
Post by Furious »
Additionally, the same happens when MAF is connected.
Re: Idle drops low
What injectors are you using?
Furious
Re: Idle drops low
Post by Furious »
There are RDX injectors (chinease cheap copy I think)
Re: Idle drops low
The injectors are most likely the issue. I would consider getting real ones.
Furious
Re: Idle drops low
Post by Furious »
Strange is that when I turned on and tune the AFM, the issue has gone away...
