B18B1/B16A Fully Built Stock Cams LS Vtec gt35 turbo block guard
aperez1999
Post by aperez1999 »
We are running a basemap made by SycRedDevil since this build is pretty close to ours but we are running stock cams (6-21-2021TESTx6357-LSVTEC-235cc-IHE-PumpGas) this tune fired up perfect and idles very well. The build had a bad water pump so for the time being we are running an LS water pump and because of that we are off timing by a half of a tooth. We thought the dizzy would solve this but it seems to rumble at idle for some reason. Including a datalog and the tune file we got from SycRedDevil's post
We are waiting for a new water pump from ebay but if anyone can take a look at the data log and lend some input feel free as we are new to the forum!
Pics of the build can be seen on Instagram
https://www.instagram.com/nof00lsgarage/
CalibratEd
Re: B18B1/B16A Fully Built Stock Cams LS Vtec gt35 turbo block guard
Post by CalibratEd »
Can you provide a datalog with wideband data?
-Ed
Instagram: calibrated.tuning
