2008 S2000 bricked flash pro
mikedoubleg
Post by mikedoubleg »
Hello,
I have 2 s2000 with flash pro. Both are AP2 with drive by wire. On my second one, I bought the car with flash pro already I stalled as it was already boosted. I unfortunately had to rebuild the motor which is fine.
My issue is I can’t connect to the flash pro module anymore. I have a new turbo and injector but can’t click on anything in the manager on that car.
What can I do?
Also, any news on offering EBC again?
Re: 2008 S2000 bricked flash pro
What is the serial umber that is on the FlashPro?
mikedoubleg
Hello,
My serial number is FP-S2K-US-31825 and i'm on flashpro manager version is 3.9.5.0 build 2689.
mikedoubleg
Hello,
Under the help menu, "Send feedback to Hondata" is grayed out and I can't select it. The key position is "On". The flashpro does blink green when the car is connected to it and also does flash green when I connect my computer to it.
I did verify that the computer works by connecting it to my other car. Is there any way to hard reset the device? I don't care about the tune stored in it as the car needs to be re-tuned as I've changed the turbo, injectors, and valvetrain.
With the USB plugged in what shows up in the lower left corner of the software?
mikedoubleg
I made a quick video below
https://youtu.be/-C_A38jkhaY
mikedoubleg
Whether I plug flash pro:
1. USB only
2. OBD2 only
3. Both USB and OBD2
The same green status light is flashing.
Send and email so support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
mikedoubleg
Sounds good. Thank you for the help. Will keep the forum updated in case someone else has the same issue.
Cheers!
