Help needed on No start. Turbo d16y7
Bberts90
Post by Bberts90 »
Can someone please help me diagnose this 2 month long problem!
Car will crank and run very momentarily then die.
*Car will start and run when map in unplugged*
The car was originally running on crome with a chipped p06, car ran great for a good 30-40 miles on my first revision from tuner, out of the blue the car while just cruising stalls on me, cranks but wont run. Pull map sensor, car runs and idles ( obv not very well). Since then i have replaced the map sensor, plugs, dizzy and now have a s300 p06 i am running but still getting the same results.
Also, sensors psp,vtp and dist error are all on. Car does not have ps or vtec (d16y7)
Re: Help needed on No start. Turbo d16y7
There are no errors reported in the datalog and if you were pressing the throttle, thee was no TPS detected. You should try the ECU in a known running vehicle with their calibration.
Bberts90
Post by Bberts90 »
I've got the car up and running thank god, could someone please shed some light on hooking my aem wideband up ( part number 30-0310) ive got the red wire going to a25 black/brown going to a26 and white to d14 but am not showing any redings when the car is running.
Bberts90
Post by Bberts90 »
figured it out, brown wire to d22. working flawlessly.
