car wont rev pass 2k while in gear but will stationary
Dtuned3
Post by Dtuned3 »
car has a basic set up css ls vtev skunk 2 cams just recently switch over to Bosch 2200cc but car goes into like a decel mode and the datalog shows injector duty cycle go to 0ms car was working fine but no matter what deadtimes i use car has the same issue any help would be appreciated thank you
Re: car wont rev pass 2k while in gear but will stationary
Post a picture of your s300.
Dtuned3
Post by Dtuned3 »
Here is the picture thanks
Dtuned3
Post by Dtuned3 »
This also happened the last time i took the car out trying to tune
The internal battery has most likely failed. The only option is to upgrade to the version 4 s300. Details and the form can be found at: https://www.hondata.com/downloads/s300v ... e_form.pdf
Dtuned3
Post by Dtuned3 »
thank you sir
