K24a turbo
andrewadkisson2001
K24a turbo
Post by andrewadkisson2001 »
I got a k24a swapped integra I got a type s pump on it with fic 1650cc injectors 535 pump and a gt3584rs psr turbo anyone possible have a base map possibly??
CalibratEd
Re: K24a turbo
Post by CalibratEd »
I may be able to help. Do you need something to get you to a tuner? Can you provide datalogs with wideband data?
-Ed
Instagram: calibrated.tuning
andrewadkisson2001
Re: K24a turbo
Just need something that will be good to break in the motor going to get a dyno tune in around a month
CalibratEd
Re: K24a turbo
andrewadkisson2001 wrote: Sat Jul 30, 2022 2:20 pm Just need something that will be good to break in the motor going to get a dyno tune in around a month
Sounds good. Are the modification you posted the only ones? Are you running a different map sensor?
-Ed
andrewadkisson2001
Re: K24a turbo
Running a Ktuned 4bar map
CalibratEd
Re: K24a turbo
andrewadkisson2001 wrote: Sat Jul 30, 2022 9:25 pm Running a Ktuned 4bar map
Do you have an aftermarket wideband?
-Ed
andrewadkisson2001
Re: K24a turbo
Yes
CalibratEd
Re: K24a turbo
andrewadkisson2001 wrote: Sun Jul 31, 2022 4:22 pm Yes
Is it connected to your kpro?
- Ed
andrewadkisson2001
Re: K24a turbo
I been trying to get it to link not 100 percent yet tho so not at the moment it’s not
CalibratEd
Re: K24a turbo
andrewadkisson2001 wrote: Mon Aug 01, 2022 5:38 pm I been trying to get it to link not 100 percent yet tho so not at the moment it’s not
Ok, reach out once it’s connected.
-Ed
