2022 Civic Si FlashPro lock issue
juddyjenks@gmail.com
Post by juddyjenks@gmail.com »
Just purchased FlashPro registered it online and when I went to lock it to car. It said need to contact Hondata support checked ECU # 37820-64B-A01 says it’s supported
Re: 2022 Civic Si FlashPro lock issue
What is the exact error message that it is giving you?
Got it fixed allow me to lock when I hooked it up again to get error code!
Question now I have is I loaded the 250 torque tune with rev hang eliminated getting check engine light with emission warning in car. Seems to run real nice!
Go to the online menu in the software and then click on OBDII diagnostics and try clearing the errors from there. If any remain, you will just need to drive it until they go away on their own.
Is this common error it says emission issue could reduce power output been driving it for couple day light is still on going to try to clear today but wanted to ask?
Also it doesn’t matter what mode Sport/Normal your in when tuning ecu correct
If you data log, what errors are reported?
Wondering with Tune on Civic the Sport Mode vs Normal doesn't really matter correct? Also what is best tune to use with 93 octane gas?
It depends on if you have Hondata mode enabled on the torque settings.
As long as you don't use the flex fuel calibration, then any can be used with 93 octane fuel.
