2006 Civic Si w/ K24 Swap is in limp mode
hamadata
Post by hamadata »
I recently got a 2006 K24 Swapped Si and I am having a couple of troubles setting it up. It has a Hondata flashpro installed and I am able to access things and even put on the base tunes for the 2006 Si on the list. My issue is that though it is a K swap, Hondata won't let me put a k24 car tune, and also with the current (stock 2006 Si) tune I have on, I cannot go above 3000 RPM. The engine codes are for knock sensor and also oxygen sensor along with a MAF sensor reading low voltage (live data shows me that the pressure is being read just fine. I am pretty new to tuning so please if anyone can bestow their expertise I'd be more than grateful. I can answer any additional questions and do anything you need me to provide further detail.
Re: 2006 Civic Si w/ K24 Swap is in limp mode
You should be able to custom tune this for larger displacement on the dyno. You do need to resolve the error codes you are getting first.
hamadata
Post by hamadata »
Thank you for your reply, is it possible for the wrong tune to cause my car to go into limo mode? Currently it has the stock tune for a civic si with the regular engine which gets it to start up and run okay however it’ll not go above 3K rpm. Could a better tune solve the issue or do I have to address the codes individually (sort of like it’s the sensors that are broken). Appreciate your time!
You should follow the factory service manual for troubleshooting the codes individually.
