Tuning VTEC OFF
DKetchie
Tuning VTEC OFF
Post by DKetchie »
New here...
Is there a correct way to turn VTEC off with flashpro? I have read things like setting the vtec engagement rpm to 10k or something crazy, but I have also read where that doesnt work. What about setting the minimum speed or min temp to a higher threshold?
I have a race on only k20z3, with vtec elimination camshafts. (only the large profile). My builder is telling me to use a vtec elimination plate to ensure better head oiling and turn the vtec off in the ecu.
If I use the vtec elimination plate and dont turn vtec off in the ecu, wont I get some kind of code and go into limp mode?
Any help would be greatly appreciated.
Thank you,
Re: Tuning VTEC OFF
There is no way to turn it off. You would have to change the settings such that they are not met to activate VTEC.
DKetchie
Re: Tuning VTEC OFF
Post by DKetchie »
Thank you,
So setting one of the parameters….like rpm, temp, or speed requirements to a number that won’t be reached is an acceptable method?
Re: Tuning VTEC OFF
That will be the only option. You should also set the VTEC point much higher than you will be revving it.
DKetchie
Re: Tuning VTEC OFF
Post by DKetchie »
Thank you
