Fk8 XDI activation code
Posted: Mon Aug 15, 2022 6:36 am
Hi guys,
I recently had my xdi high pressure fuel pump installed on my fk8 type R. After install I had went to the flash pro tab as advised on the sheet with the code included with the pump. I was NOT able to insert the code or serial number as I could not click on the provided spaces. Along with this it had already said enabled in that same area below.
Car started and ran fine, but I’ve been told by xdi I need this activate to use the pumps full controls. Is this a glitch in the software?
I am just concerned I may not be getting the full potential of the pump. Later that day I had brought my car to the dyno and the tuner also said the pump was activated already. Could not hit the commanded target at peak boost pressure.
Please let me know ASAP as I’m trying to diagnose a fuel issue and want to rule this out.
Thanks in advance!!
Thanks in advance!!
