s300 Firmware Update Failed, Now wont Connect to ECU
jeremysaliba
Post by jeremysaliba »
Hi, so today I needed to some adjustments to a tune and the SManager required an update and that succeeded with no issues. Then I got a pop-up for a firmware update.
I started the firmware updating process and for some reason the progress bar didnt move at all for a couple of minutes followed by the SManager crashing afterwards. Now Im trying to to connect to the ECU but Im getting upload/download access(basically no ability to edit anything). Hoping I just did something dumb and Its a simple fix.
Note: Its an S300 V3.
Awaiting your earliest reply.
Thank you
Re: s300 Firmware Update Failed, Now wont Connect to ECU
jeremysaliba
It is version 2.7.8.0 from 10th January 2022. I was trying to find a way to retry the firmware update but it just wont connect so cant really do much. Is there a kind of factory reset on the board? Hoping that it will use the older version firmware until I try reupdate it to the most updated one. Im just guessing here to be honest.
With regards to the serial number I will check on that tomorrow first thing as here its already 10.30pm and Ill update on this matter when I have the digits.
Edit: Just thought of this also.Could it be that the old firmware + new 2.7.8.0 wont work together? In that case Ill redownload the older version and see if it will work.
Do not backdate the software.
ky479
Post by ky479 »
Did you remove the s300 out of the ecu for whatever reason.
