PRA ecu boost control
Knox
Post by Knox »
Hello, I have some research and found that PRA, PRC, PRD ecus can't control nitrous. (viewtopic.php?t=5764) but on the software I sew that for output I can use AC output also, so I want to ask if I use AC output (so remove AC from the car), can I use nitrous wit PRA ecu?
Thank you.
Re: PRA ecu boost control
Are you trying to use this as boost control?
Knox
Post by Knox »
No, I want to control nitrous solenoid. I saw on the software that software allow to use ac output as nitrous output so, I tought may be if I delete ac I can trigger the nitrous solenoid with pra ecu.
You should be able to use the inputs an outputs listed that are not emissions controls as long as there is already a wire in the harness at the ECU for it.
