Launch Control RPM not being set
rollin71
Post by rollin71 »
I have a 2013 civic si with Flashpro and I wanted to raise the launch RPM from 3500 to 5500. I have set the rpm in the calibration and I am using the newest firmware and software. I have saved multiple times while editing the calibration and its saved fine. The config also uploaded to the flashpro without any issues. I upload the config in my car and the launch RPM is still set to 3500. Any help would be appreciated.
Re: Launch Control RPM not being set
Post the calibration as well as a datalog showing the issue.
rollin71
Post by rollin71 »
Here is the calibration file. I will do a quick datalog and post that next
rollin71
Post by rollin71 »
Here is the datalog file. Let me know if you need anything further.
Does your cruise control work as it should?
rollin71
Post by rollin71 »
Yes it does
Have you tried adjusting it as it says in the help file: https://www.hondata.com/help/flashpro/l ... sub=launch
rollin71
Post by rollin71 »
I don't know if it had to do with the fact that the cruise control was accidentally on but after I uploaded the calibration and disconnected the battery everything worked as expected. Once I reconnected the battery and went out on a test drive the launch control rpm was set properly. Thank you again for the help.
